I need to purchase u joints for my front drive axle. What do you recommend? Spicer is a big one I hear. Any particular one?
2000 TJ 2.5L manual
2000 TJ 2.5L manual
thanks a lot Jerry. So the axle shaft that connect the transfercase to the front differential needs two spicer 5-1310x, correct?For your front axle shafts go with Spicer 5-760x which is a direct replacement and both stronger and more durable than the Spicer 297 u-joints the factory installed. For your Driveshafts Spicer 5-1310x for similar reasons, they are stronger and more durable than the Spicers the factory installed.
Decent website for u-joints and other parts. They have the chart below on the link. Just look for your year and Rubicon or not. Greaseable or non (Many recommend non-greaseable for strength) 5-1310X is what you would want. If you are rebuilding the whole driveshaft then go ahead and replace the CV joint.My bad on not using the right terms. I was talking about the front driveshaft (connecting Tcase to the front differential).
-1310x f
https://www.dennysdriveshaft.com/c977_universal_joints_wrangler_tj.html
This would be the whole kit for the driveshaft.
https://www.dennysdriveshaft.com/p3..._for_jeep_with_oem_1310_series_non_greas.html
Yes though your front driveshaft actually needs three of them. One at the front and two at the rear.thanks a lot Jerry. So the axle shaft that connect the transfer case to the front differential needs two spicer 5-1310x, correct?
