I have a 99 2.5 liter wrangler. My engine makes a tapping/ slapping/ tick noise that is louder when your under the Jeep. Sounds like the rattle inside a paint spray can sometimes.
I have been chasing this noise for a long time. I was told it was the timing chain. And water pump. Those did not resolve it. It was louder at start up and would make the Jeep idle like crap for a bit.
Things I have replaced.
Timing chain
Transmission
Oil pan . Had big dent in it
Oil sending unit
Cat
Water pump
Thermostat
A lot of sensors
O2 sensors
Spark plugs from dealer.
It has a crack in the gas tank so I can only fill it half way.
Am I looking at a manifold crack? One guy said it was just noisy lifters and it will prob run that way for a long time. It was getting worse every day. Seems to be slightly better after replacing the spark plugs. I added an oil thickening agent that I used to use in my old truck. I can do basic things that just take logic but most of this has been done my a mechanic and nothing has changed this noise or idle issue beside the snow it’s a lot less loud.
Timing chain
Transmission
Oil sending unit
Cat
Water pump
Thermostat
A lot of sensors
O2 sensors
