Hello,
New member, long time wheeler..
Thought it would be a good idea to document my build process as a place to store part numbers as it evolves and ask advice as I go.
Really fortunate to buy this well built Jeep. 2 weeks after I brought it home, I drove from South OC to the Rubicon, did the trail in one day, and drove home without a single problem.
Current specs:
Front Axle:
Dana 44 out of a F150 with 1983 K10 hub and brake conversion
Measures 67 inch hub to hub
Parts Mike tie rod ends (both are standard thread) (possible replacement part numbers ES2234R or ES2010R)
RCV axles
Warn locking hubs
ARB
4.56
5 by 5 1/2
Factory sway bar with disconnect
Rear Axle:
Rock Jock 60
Measures 65 inch hub to hub
4.56
ARB
5 by 5 1/2
Ford Explorer brakes
Currie Anti Rock sway bar
Suspension:
Custom 4 link rear, 3link front
King 2 1/2 coils with bypass
Steering:
PSC ram assist
Tires:
37 inch Goodyear MT/R
Mounted on Raceline Beadlocks. Rings are powder coated silver.
Poison Spider tire carrier with full size spare and beadlock
Ramsey 9500
Gen Right fenders and full body armor powder coated silver.
Poison Spyder hood powder coated silver.
New front driveshaft from Drivelines Incorporated with 1330 joints throughout.
Novak cable shifter for the transfer case.
ARB twin compressor. Plumbed to a 6 port 1/4 npt manifold. Manifold consists of 2 ARB solenoids, blow off switch and, air hose coupler. Braided stainless lines to both axles.
Replaced the factory switch panel below the radio with a custom fabricated piece and 6 switch panel with lighter, usb, and air pressure gauge.
Factory soft top and Best Top bikini top with Best Top wind screen
Replaced the factory speakers. Replaced factory sub with 6” kicker.
Current specs:
Front Axle:
RCV axles
Warn locking hubs
ARB
4.56
5 by 5 1/2
Rear Axle:
Rock Jock 60
4.56
ARB
5 by 5 1/2
Suspension:
Steering:
PSC ram assist
Tires:
Ramsey 9500
