I ordered new ball joints (Spicer 706944X). I removed everything except the steering knuckle. I used a pickle fork to remove the steering knuckle. When I used the pickle fork on the upper ball joint, the steering knuckle came loose but to my surprise, the upper ball joint came right off. It turns out the upper hole in the inner C is now too large for the ball joint. Has anyone else had this problem? The bottom ball joint is still in the inner C and will need to be pressed out. I am hoping the upper spicer ball joint will fit. If not, what are my options?
Appreciate any and all comments.
