Jeep suddenly has vibration ~50MPH and above. Never had issue like this in five years. 85k miles.
New front U-joint and transfer case skid plate spacers (1/8" washers) is only recent change. Guy said washers help reduce rust formation.
I marked DS for alignment with yokes, they're OK on both ends, everything is torqued and centered.
Nothing apparent with tires, no bulges, lugs tight, no missing wheel weights.
Apparent whether in gear or neutral. Not especially apparent in steering, shifter or TC lever. Feel in whole Jeep, like it's a consistently bumpy road
UPDATE Removed skid spacers, retorqued skid, trans mount and u-bolts on u-joints, examined tires carefully, no meaningful change. I'll try rotating tires then remove front DS. Really seems like a tire issue, maybe a broken belt.
UPDATE- Rebuilt front DS with new DC and checked and found rear DS joints all good. Drove without front DS then later without rear DS, vibration still there.
Found a little play in front wheel bearing replaced with Spicer, vibration remains.
Had wheels rebalanced, 3 needed weights but only ~1.5 ozs. at most tech said no sign of broken belts, tires look true
Ball joints look fine as does steering linkage.
Front upper control arm bushing looks a little soft on R side, appears very slight. Also, axle U-joint on R side has very slight play. Could these be cause?
Running out of ideas
Thoughts to share?
Thanks
Thoughts to share?
Thanks
