Vibration around 50 mph
Kenneth G Zinis
Bethlehem, PA
Jeep suddenly has vibration ~50MPH and above. Never had issue like this in five years. 85k miles.
New front U-joint and transfer case skid plate spacers (1/8" washers) is only recent change. Guy said washers help reduce rust formation.
I marked DS for alignment with yokes, they're OK on both ends, everything is torqued and centered.
Nothing apparent with tires, no bulges, lugs tight, no missing wheel weights.
Apparent whether in gear or neutral. Not especially apparent in steering, shifter or TC lever. Feel in whole Jeep, like it's a consistently bumpy road
UPDATE Removed skid spacers, retorqued skid, trans mount and u-bolts on u-joints, examined tires carefully, no meaningful change. I'll try rotating tires then remove front DS. Really seems like a tire issue, maybe a broken belt.
Any suggestions?
Thanks
