Fughuert
I personally would not ever overlap panels but it’s fine if you don’t care how it looks and are gonna seam seal it.
You absolutely can weld these panels with flux core, it’s messier than a gas process and you shouldn’t overlap your tacks until you clean each prior one, I mean wire wheel each tack before welding over one.
Take your time, cool it down with a damp rag or compressed air if you’re getting impatient, don’t let it get too hot it will become a nightmare.
From all the boogers it looks like you’re too cold and trying to run a bead? Turn up a bit and sit in one spot make a nice tack, really let a puddle form then stop, jump a few inches down and repeat. Wire wheel em all at once then jump back and put another tack over the series of ones you just laid, repeat til solid.
I welded a patch in my rear taillight panel with stick, you can do this with flux core, keep watching YouTube videos. Other people have done it you can too.
Before & after
Before & after
