What after market amplifier, if any, can be fitted inside the console on a 2004 Wrangler TJ? Apparently the original one is defective.
I'd be wary of placing any amplifier that puts out much power inside the console where there would be zero air circulation. They can get hot and die if they can't dissipate their heat.
Powerful means lots of watts which means lots of heat is generated. That's not a problem in the open air but not in a small confined area with zero air circulation like inside the console.Agreed with Jerry, but Soundigital makes some small powerful amps.
Where did u place it? Also is this the sub youd recommend too?You'll find this is one of the most popular options for small amps that fits easily:
https://www.amazon.com/dp/B00UG7AK66/?tag=wranglerorg-20
I ran that one on my last TJ.
https://www.amazon.com/dp/B01BLVEZG6/?tag=wranglerorg-20
Can this be somehow connected through the same harness that's already available? That's my main reason to consider in side the console.
Stock head unit? Please clarify. I traced connections from the radio radio connector to the sub amp connector and all have continuity.
I am not at all familiarized on how the "defective" amplifier works. If it is only amplifying the sub or all speakers.
