Hello all,
Working on replacing my battery cables and lugs - they're both fairly shot.
Anyways, the only thing I have a question on is on the fusible link between the battery and the alternator. I'm looking to replace the fusible link with an in-line fuse, and am wondering what AMP fuse I should get. The P/N for my alternator is 56041864AA, which doing a google search shows as 117 amp, but then I read else-wear that the fuse should be based on the alternator wire. I will be using 6 AWG for this (same that custombatterycables.com uses), and a google search shows that max Amperage for 6 AWG is 75 so I'm a bit confused.
Also, for actually holding the in line mega-fuse, what solution did you all come up with? I can't simply bolt the in line fuse to the alternator and bolt the alternator cable to the fuse, right? Would I have to mount a fuse holder to the fender and run two separate wires to and from the holder?
Thanks is advance!
Thanks is advance!
