I need a a brake booster and master cylinder for my 05 Rubicon. I know people have said the Crown units are no good. The only other option I see is Mopar which is very expensive. Thoughts?
While Mopar is certainly the way to go....
Are your brakes factory or have they been modified ?
IF you are unsure what components to use... @mrblaine is certainly the expert when it comes to braking systems.
I was talking to Blaine yesterday about why I can't break in the pads. We came to the conclusion that the booster/master cylinder are worn out causing the calipers to not have enough clamping force to get the pads hot enough and break them in.
