4.56 is ideal for 33's when you have the 4.0 engine and 5-speed transmission. Wisconsin is flat enough that you don't need anything steeper like 4.88. Don't let anyone talk you into 4.10!Got 33s on stock gear assembly. What gear assembly should I upgrade to make it ride like stock. My max speed is 70mph right now but that’s not bad but I won’t some stress relieved off my engine.
Second what Jerry advises. Have the same setup (33's/4.0/5 sp) I went with 4.88 only in anticipation of moving to 35's next time I need rubber. 4.56 gearing would be perfect if you are sticking with current tire size.4.56 is ideal for 33's when you have the 4.0 engine and 5-speed transmission. Don't let anyone talk you into 4.10!
4.88 is better for 33s. 5.13 for 35s.Second what Jerry advises. Have the same setup (33's/4.0/5 sp) I went with 4.88 only in anticipation of moving to 35's next time I need rubber. 4.56 gearing would be perfect if you are sticking with current tire size.
Sounds like it’s time to get a new speedo gear or a speedohealerGuys disregard this thread my speedometer was wrong I reach 86 which is plenty enough but I’ll prolly upgrade up to a 4.56 to relieve my engine in the future
You say that now, but might eat those words after installing 35's and realize the then lost performance. I recommend 4.88 for 33's long term, 5.13 if planning 35's.Second what Jerry advises. Have the same setup (33's/4.0/5 sp) I went with 4.88 only in anticipation of moving to 35's next time I need rubber. 4.56 gearing would be perfect if you are sticking with current tire size.
I think a set of 3.07:1 gears would be perfect for your application. I just so happen to have a set I’d be willing to part with…Got 33s on stock gear assembly. What gear assembly should I upgrade to make it ride like stock. My max speed is 70mph right now but that’s not bad but I won’t some stress relieved off my engine.
I have the same config but have a 6 SPEED NSG370 close ration with a .84 overdrive in 6th gear, does your 4:56 recommendation still apply to my 6 speed TJ? Not really interested in wheeling as mush as a driving to work or the beach. I was thinking the 6 speed might help get away with a 4.10.4.56 is ideal for 33's when you have the 4.0 engine and 5-speed transmission. Wisconsin is flat enough that you don't need anything steeper like 4.88. Don't let anyone talk you into 4.10!
My last Jeep was an LJ on 35’s with the 6 speed and 4.88’s, in my opinion, it was perfect. The 6 speeds relatively short overdrive ratio make gear selection a bit different then either of the 5 speeds.I have the same config but have a 6 SPEED NSG370 close ration with a .84 overdrive in 6th gear, does your 4:56 recommendation still apply to my 6 speed TJ? Not really interested in wheeling as mush as a driving to work or the beach. I was thinking the 6 speed might help get away with a 4.10.
