What is the fuel pressure on the 1997 TJ supposed to be?
45 psi is enough to start. Are you getting spark???
My jeep stalled a few days ago about 2 miles after I got gas. Cranks but won't turn over. Changed the CPS, IAC, MAP, TPS, starter solenoid, ignition switch, and ignition actuator pin. And checked the starter brushes. I'm on a time crunch and these things all helped in the past.
I can't hear the fuel pump when I key it on (not sure if I'm supposed to) but I checked the pressure last night and it read 44-45 when I keyed it on each time. It didn't change when I cranked it. Not sure how to interpret that.
You asked about getting a spark. A new coil pack fixed a similar issue in the past as well. How else do you test for that?
