What about an 02 4.0? Amazon says the pump fits but not the full assemblyMy guide shows Bosch 69316 for the fuel pump itself for a 2003 4.0 as well. Amazon shows it correct too... https://www.amazon.com/dp/B000BZL922/?tag=wranglerorg-20
The above mentioned Bosch 67726 for the entire fuel pump assembly is correct too, it includes everything including the enclosure, fuel gauge sender, and fuel pressure regulator. The 67726 would be easier to install though it costs more. https://www.amazon.com/dp/B001C64PWU/?tag=wranglerorg-20
hey jerry I'm having to turn the key off an on. 2 or 3 times for a quick start...should I put the Bosch pump in right away or am I safe to drive it awhile,,,,its my daily an monsoon season so I want to do it in sept....My guide shows Bosch 69316 for the fuel pump itself for a 2003 4.0 as well. Amazon shows it correct too... https://www.amazon.com/dp/B000BZL922/?tag=wranglerorg-20
It won't hurt anything to cycle the pump as many times as it needs to get fuel up the the engine.hey jerry I'm having to turn the key off an on. 2 or 3 times for a quick start...should I put the Bosch pump in right away or am I safe to drive it awhile,,,,its my daily an monsoon season so I want to do it in sept....
I got one on amazon 67726...
thnx i jus dient want to get stuck out jeeping or partying in Gilbert .It won't hurt anything to cycle the pump as many times as it needs to get fuel up the the engine.
Since you already got the pump it wouldn't be a bad idea to throw it into the back of the Jeep. I really doubt you'll need it but...thnx i jus dient want to get stuck out jeeping or partying in Gilbert .
don't know if there's enough room for the box in back,,,hahahahahaha plus the dog...it's not a LJSince you already got the pump it wouldn't be a bad idea to throw it into the back of the Jeep. I really doubt you'll need it but...
