U up on the mountain. TJ Enthusiast Joined Apr 8, 2021 Messages 120 Location crestline california Oct 2, 2021 #1 I need the tool to disconnect my auto trans lines from my radiator. 05 tj. anybody out there that could shed some light?
P pagrey TJ Guru Supporting Member Joined Apr 10, 2018 Messages 7,725 Location Los Angeles, CA, USA Oct 2, 2021 #2 They are GM quick connect fittings, lots of places sell the tools. Don't know a specific part number or anything, mine doesn't use them.
TheBoogieman Disturbed Jeepaholic Supporting Member Joined Jan 1, 2019 Messages 11,558 Location CharlottesHELL, VA Oct 2, 2021 #3 I used a Sharpie marker cap to disconnect mine. Cut the closed tip off and a slit down the side to slip it on the line. Worked like a charm.
zebra12 TJJ78 and TJJ77 Supporting Member Joined Apr 9, 2018 Messages 2,236 Location Corvallis, Oregon Oct 2, 2021 #4 I use this one: https://www.amazon.com/dp/B000OCIWR2/?tag=wranglerorg-20 It works well. The low profile ones look handy too.
OP U up on the mountain. TJ Enthusiast Joined Apr 8, 2021 Messages 120 Location crestline california Oct 3, 2021 #5 Thanks guys for the info.
TheBoogieman Disturbed Jeepaholic Supporting Member Joined Jan 1, 2019 Messages 11,558 Location CharlottesHELL, VA Oct 3, 2021 #6 zebra12 said: I use this one: https://www.amazon.com/dp/B000OCIWR2/?tag=wranglerorg-20 It works well. The low profile ones look handy too. Click to expand... Sharpie cap works just as good and costs way less ($1 for 2) for something you'll rarely use.
Superjay5 TJ Enthusiast Lifetime Supporting Member Joined Oct 20, 2020 Messages 468 Location Michigan Oct 3, 2021 #7 I just pulled these from my buddys jeep, I just used a pick…. Not sure why you would need a special tool?
L LukesfirstJeep TJ Addict Supporting Member Joined Aug 2, 2018 Messages 1,414 Location Central PA Oct 3, 2021 #8 I just pulled these from my buddys jeep, I just used a pick…. Not sure why you would need a special tool? Click to expand... I've done the same with a pick or small screwdriver, but I think the tool makes it easier when you go to install the clip.
