I know, and you're absolutely right.The bushings, axle and arm are all thru bolted and all I am saying is that in rust belt jeeps it all fuses together, your in the PNW and probably not used to that. I had my front axle out on the floor during my frame swap and it took an arsenal to disconnect the control arm from the axle.
His axle is also prettier than mine, and is already free from arms. A ball joint press is a good method from removing the bushings.
