I just put adapters on my ‘98 Sahara. The studs on the adapters are just about perfect length but I noticed when using the open end nut to mount the adapter to the hub, the stock studs are really short and the stud doesn’t stick out of the nut at all. In fact it is about 1/8-1/4” from even being flush. I tried mounting my stock wheel up with the open end nut without the adapter and the fit is about the same, I just never noticed with the closed end stock nut. I want to replace the studs with something a little longer, does anyone have the stock stud specs? I know they are 1/2x20 but I need the knurl size and stud length too. Are all of the studs the same or are they different front/rear, disc/drum, 30/35/44, etc? I really don’t want to knock a couple of studs out to check since the adapters are already loctited in, hope someone can help me out.
