Question since I'm relatively new to this hobby regarding axle strength.
I broke the passenger side u-joint last sunday. Wasn't beating the jeep was climbing a waterfall kind on thing and the wheels were straight, I clutched it and it rolled backwards some, let out on the clutch (no gas applied) and it popped. Joint looked like it had adequate lube in it. Probably original joints on a 203K non-wheeled jeep until now.
So when you break a joint, is it because of the lack of material in the yoke?
(My inner shaft has one egg shaped ear and both shaft yokes are spread)
Are G-2, Ten Factory, Revolution, or RCV the answer?
Would you just chase the break deeper into the driveline? (break the differential)
