I have access to some fancy magnetic switches that are equipped with a set of double contacts. I'd like to install one in the clutch safety circuit and the starter solenoid circuit as an anti-theft device. I have the location all ironed out for the switch, and all the details of operation worked out. What I need most, is a location in the wiring harness where all 4 of the wires I need to tap into are located, preferably at the same location since the switch has a quick disconnect 4 wire cable. I'm assuming that the thru-firewall harness has everything I need in a convenient location. An electrical schematic would be helpful, but previous experience is more preferred. This is on a 97 TJ.
Thanks!
Thanks!
