Trying to set up my front pinion angle. 5.5" of lift. Driveshaft angle is sitting right at 10 degrees. Setting the upper Control arms to the charts I found online (15-5/8")has my pinion way to low. If I understand it right I want my pinion angle to match the drive shaft correct, so 10 degrees? Can I measure this on the top of the yoke or on top of the pinion snout on the housing? I had a hell of a time getting the axle rotated last night just to end up with the pinion almost at 2 degrees and just want to make sure Im measuring at the correct spot.
