So picking apart my 05 rubicon I bought and noticed the air sensor is ghetto rigged mounted. Can someone tell me where it is suppose to be. The intake hose does not have a port for it. Also with it being mounted like that what issues could it cause
The correct intake tube has a port for it on the back side.So picking apart my 05 rubicon I bought and noticed the air sensor is ghetto rigged mounted. Can someone tell me where it is suppose to be. The intake hose does not have a port for it. Also with it being mounted like that what issues could it cause
Can't say for sure but the point is that it's supposed to be monitoring the intake air, not the air in the engine compartment. The intake tube that you have is for an earlier model (pre '03, I think) where the PCV intake was on the tube. Your '05 should have the PCV intake on the air box and not on the tube...and the air sensor should be mounted on the firewall side of the tube. Here's a pic (not my TJ) that shows the PCV intake line correctly routed to the air filter box and the sensor mounting in the back of the air intake tube.Thanks. What issues would it be causing be mounted where it is now. I noticed my fan seems on always on. Did a clutch test by shutting vehicle off and fan does stop immediately. Just wondering if that can relate to that sensor
IMO Please forget this idea as its a waste of money when the stock functions perfectly fine.get a aftermarket cold air
Complete waste of $$$ for a Wrangler IMHO.The existing intake sucks hot air from the under the hood, not good. Banks Power makes a cold air intake that truly does get air from outside. I have found that Banks Power is a good source for 2005 and 2006 TJ/LJ performance parts as Gale Banks owns an LJ and makes the products first for his Jeep then sales it to the public. This intake kit does require you cut your hood, see attached.
I have an 04 and mine routes to the tube.I have an 03 and was curious about the intake tube. What years had the hose routed to the filter?
Thanks! I just switched from a cold air to the stock and was slightly concerned I did something wrong lol.I have an 04 and mine routes to the tube.
I believe 05-06 were the years that had the tube going directly to the airbox.Thanks! I just switched from a cold air to the stock and was slightly concerned I did something wrong lol.
According to the service manuals, that is correct. It was a DC change.I believe 05-06 were the years that had the tube going directly to the airbox.
