This may be post of the day.
Assess the vehicle. Here is a basic rundown of a used TJ -
Needs sway bar links and a bushing or two
One tie rod end or more
Some Wire/Cables need ziptied
Toe needs set
Needs cleaned up terribly
Needs 2-3 bulbs
Needs bolts tightened, needs a lot soaked in penetrant to be loosened (shock bolts , rear seat mount bolts , etc )
Need wiper blades.
Has a 1968 penny super glued it seems to the cup holder
Needs fluids
Tire pressure varies 10lbs
Transfer case Linkage has never been lubed or adjusted
Has 1-2 CEL codes
Need fresh fuel
The door hinge pin bolts are gone.
One top zipper is damaged.
The short of it is get to know it, see what you have, as you plan your build. Then find out what a build is. A real build is
@Plumber1,
@toximus ,
@nicksjeep,
@DrDmoney, @ tworley and many more ....it isn't just changing stuff or seeing what the biggest tires you can put under it are .
It is knowing exactly what you want it to do , where to go , and what you need to do to accomplish that.
This is the right place for that.
Welcome to The TJ Wrangler Forum.
