wheels7 Member Joined Sep 6, 2019 Messages 30 Location California Nov 22, 2019 #1 Where would the drips show up/come from if the front seal on my auto transmission was leaking?
reddvltj TJ Guru Supporting Member Joined Apr 15, 2019 Messages 9,777 Location Challis, ID Nov 22, 2019 #2 I would think directly below the inspection cover unless it's running back along the pan then it could be anywhere along the pan.
OP wheels7 Member Joined Sep 6, 2019 Messages 30 Location California Nov 23, 2019 #3 Thanks much. Jack Reactions: reddvltj
reddvltj TJ Guru Supporting Member Joined Apr 15, 2019 Messages 9,777 Location Challis, ID Nov 23, 2019 #4 wheels7 said: Thanks much. Jack Click to expand... Have you removed the inspection cover to see if there is any evidence of a leak between the torque converter and transmission?
Chris Administrator Staff Member Ride of the Month Winner Joined Sep 28, 2015 Messages 71,102 Location Gillette, WY Nov 23, 2019 #5 Sometimes it's from the pan gasket too. Reactions: reddvltj
