Can you set aside your personal bias towards your purchase, and say that there is a felt difference and it was worth it?
I saw his video of justifying it, but it looked like he shifted it into 4low and tried to sell that as a magical effect of his flywheel.
Here is my opinion of the Centerforce flywheel.
It does change the shifting properties on the road. In my case I think it is an improvement but it may not be in every case. Previously I would feather the throttle between shifts to keep the RPMs close enough to where I could drop the clutch. After installation, I had to unlearn that and not feather the throttle. It actually is timed pretty well where I can shift and drop the clutch and stomp the gas without any jerking.
It also does seem to make it mildly harder to stall when being stupid with the clutch. Even with 4.10s and 35s I still often start from 2nd.
It has a mild effect of reducing vibrations when idling along in gear. It definitely does not eliminate them, but dampens them.
It also modestly reduces change in RPM from changing loads. At freeway speeds you will not notice anything at all. But hit an obstacle while idling in 4Low and it can be noticeable.
The flywheel itself fits pretty much within the profile of the factory flywheel. I believe the difference is roughly 25 versus 40 lbs. However, much of the added mass is closer to the center, so it doesn't have as large as an impact on rotational inertia as the difference in weight alone would.
I have no way to really establish the increase in rotational inertia, but if I had to guess, probably around 25-30%.
So it is not an earth-shattering change. It is for the most part subtle, and you will have to adapt your driving style slightly. Do not buy it with the expectation it will cure every problem.
Looking back at it, I probably would buy it again. But it is definitely not for everyone, especially at the price at which it is sold.
