Looking into a new steering gear. Quite a bit of play in mine. What’s everyone using as replacements ?
New PSC. You can get a Lares new for half but it's rolling the dice. I rarely recommend expensive parts but this is one that is going to hurt no matter how you look at it. I think 2005 is Mercedes unless you convert it to an older mount. If you really want to save money you can try a cheap rebuilt box but plan on doing the job a few times until you get one that works or is better than what you've got.
My 04 has a Mercedes box.
Saginaw style box or Mercedes?
Hmm , I’m not sure. I’m going to have to research that. Guess I was thinking there was only one style.
97-02 or 03-06?
It would be very rare for your Jeep to have anything but Mercedes. If yours was converted you'll have to check it to see, solid metal cast box sticking down in the front generally it's Mercedes, pressed on cap and it's not.
Don’t worry about the steering gear yet. For the time being, install V8 ZJ or Currie steering linkage. Right now you have Inverted T which is garbage for handling. That steep angle on your drag link directly causes vagueness in handling because your tie rod rolls to a limit each time you turn in the opposite direction.
Somebody deviated from stock in a misguided effort. Assuming the steering knuckles have not been reamed out larger for 1-ton tie rod ends, you can bolt on the stock style steering once again and fix that part of the issue. You may have steering box issues but that steering linkage is definitely contributing to the vagueness so you need to address it first.
Guess no one explained the power steering test yet?
Machoheadgames- as a bandaid to his tie-rod induced steering vagueness, the OP could install Ruff Stuff's "The Cure" on those tie-rod ends. They make a Delrin spacer that prevents the tie-rod from rolling. It should help as a short term fix till he comes up with a better long term solution.
I put a readhead box in mine a few weeks ago and I've been happy so far.
Was it a 03 up Mercedes box?
