Well, I just found out about that, so now I’m all screwed up. Or is it all bolted up?Except for the whole tap bolt thing.
Wait until you find out how they figure out how much thread to put on a partially threaded fastener.Well, I just found out about that, so now I’m all screwed up. Or is it all bolted up?
2x diameter +1/4” under 6” and 2x diameter +1/2” over 6”Wait until you find out how they figure out how much thread to put on a partially threaded fastener.
Something I can never seem to remember.2x diameter +1/4” under 6” and 2x diameter +1/2” over 6”
McMaster used to list the unthreaded portion, now on the grade 8 stuff, they just list 2" minimum thread which is about useless.I know there’s a formula, but there’s no reason to memorize it, since the threaded length is usually easy to look up. Before the Internet, the McMaster-Carr catalog and Machinery’s Handbook were my go-tos.
An960-6 is a mil spec washer used with 3/8 bolts, if you need the countersunk for a radius, try https://www.gen-aircraft-hardware.com/images/pdf/nas1587.pdfThey are a reduced drive flange head. The washer is just slightly larger than the flange diameter so it is a perfect washer for what I am using it for. If I can't find the same then I may have to switch but I'd rather just get more of the same since they are made, they do have them, I just can't find them.
416/421 in some hardnesses have a better tensile strengthBlaine - what type of stainless is stronger than grade 8?
