I just took off my left rear drum to apply some brake grease to fix a slight squeak. Upon reassembly, I noticed the adjuster arm/lever is sitting pretty far from the adjustment wheel. Is the tension going to pull that back upon applying the brakes or the parking brake? I have the tension wire routed alone the guide. It is too hot out there to keep messing with it... I'll check it tomorrow after a test drive.
Thanks,
John
Thanks,
John
