Do i need to link to your Host F550 thread Lol
We all have a pit.
We all have a pit.
Damn that's starting to look good!!Next was to mount the grill. WOW I haven't seen this sight for over 3 years now and I actually think it is more like 6 to 8 years since I'd pulled the grill off.
Yep I had to take tons of pictures since this is a NEW sight.
Got the wiring fed back thru the grill and trying to remember how it's laid out along the fender.
Got to remember what I did with the PDC mount bracket.
Then started getting stuff mounted to the inner fenders, Driver's side first since it has most of the junk.
Things are starting to look like they belong.
Still have to weld on the front grill support but got it mounted to the grill so I can tack it onto the front tube.
Steering box clears the grill just fine.
Need to drill and tap the shock tower for this bracket for the EVAP canister. Had to do some bending of the bracket to make it fit but I think I've got it figured out.
I am still trying to figure out the placement of the horns on the inner fender but had to bend the mounting brackets some. About this point it was time to call it a day. I've got an appointment to pick up my other sockets tomorrow, so I won't get anything done on the Jeep. But while I'm in town I can pick up gear oil for the axles and t-case. There are a few other things I need but of course can't remember what right now. Need to make a LIST.
Kind of MOTIVATES me to want to get more of it done now. The hose clamps I needed for the transmission & power steering cooler will be here tomorrow so I can start getting everything plumbed. Then I can install the radiator and hook everything up and then be able to run the engine for a longer time. Once all that's done then I can attack the axles so they can go under the Jeep for the LAST time I hope. It ain't CLOSE but DAMN it's a lot closer than it was.
Good job buddy! Love seeing that grill mounted. Great progress.
Thanks, been a LONG time coming.
I mounted my horns in the grill in the bottom outside corners basically under the headlights. I don't plan on installing the blinkers there so it worked for me
Progress is looking awesome
Yes I extended the wiring but no they are not stock horns. They are the ricer (Hella, red) car horn. They were on clearance under 10 bucks I believe lol.
They are much louder than the stock horns but they are higher pitched. If you can imagine the road runner beep, beep, only higher.
Sweeeeeeeeeeeeeeeeeeeeeeeet progress!
