This bracket for the transmission was a process. The one that Chris over on JeepForum had a indent in the middle to keep the bracket from moving. Mine of course is different.
It had this part lower than the back.
So I took a piece of flat stock about the same thickness and cut it off to match the shape of the tab.
Drilled out the hole for the bolt and then traced the angle the top bracket needed to sit.
Then I tacked the two pieces together.
But now I needed to make it flat all the way across for the bolt head to sit.
I cut a washer in half to fit.
And welded it together.
Then checked ✔ it on the transmission.
The little bit of the washer sticking out will help to keep it on the transmission and not rotate.
While it isn't a large amount of force being applied if there isn't something to keep it from routing it might over time.
Tomorrow I'll drill the hole in the floorboard and hook the cable up and test it out.
