Will a 2004 driver seat tilt forward at the base?
AndyG
Because some other guys are perverts
Lifetime Supporting Member
Alabama
Will a 2004 driver seat till forward at the base-
I am moving some parts around and wanted to know if my security console will fit in my 2004 that is
currently at the gear shop
The seat in my '04 tilts forward at the base, tilt and tumble(?).
Edit to add: my PASSENGER seat 🤦‍♂️
I had a 2004 and have a 2006 LJR. The driver's seat did not tilt forward in the 2004, it does in the 2006.
If you are installing a Tuffy Security console, I put one in my 2004 with no issues. It's easier to do if you remove the seats.
Good luck!
Maybe check your build sheet. I think it was an optional feature. Not very common, I think. My 04 only has a passenger tip.
