I wouldn't rule out a wiring issue given all the weird symptoms, especially the sensor harness that runs all the way to the fuel pump in the back. The sensor return (aka sensor ground) touches a dozen engine sensors (incl 02), switches, and clock-spring before feeding into pin C1-A4 on the ECM. I also have a gremlin that keeps coming back causing poor idle, stumble at mid-rpm. I'm fixin' to pull the whole under-neath harness out, pull all the loom, inspect-repair, and reinstall. Loom is cheap. Just waiting for it to warm up a bit in the next few weeks.
First, I'll pull the lower cover off the steering column and recheck all the connectors going to the clock-spring since replacing that cleared it up before. I'm also going to check the resistance from the sensor ground at the speedo sensor to C1-A4 and wiggle a few things. Might get lucky.
