2000 grand cherokee to a 2004 Rubicon ... motor and trans.. both 4.0 and 4 speed auto... deat brother got scrapped by a semi and may want to sell it ... I may get it if they fit and part out the rest
What exactly is the question? Neither your thread title or post itself has anything formatted in question form. That’s an important detail I’d say.Guess nobody knows ... I'm sure someone does but ok
Why... lifter tick... needs rebuild after 391k miles ... free engine is better than none... gotta pull the engine to replace cam or disassemble the entire front end .. grill condenser radiator .. and hopes it comes out ... easier to swap block and headWhy do you want to do this?
Yeah I saw something about the heads cracking .. his grand has 138k miles ... ok ..looked up prices and it's about 400 to replace cam and lifters with head gasket set... thought the cam was 500 alone was why I wanted to do it.. for that price me and the kid could change them out one weekend.. can't go without the jeep as it's daily driven .. and don't wanna pull the engine unless rebuild or replaceThe engine will swap easily but the transmission is slightly different. Also keep in mind the cylinder heads in 2000 had a defect that caused some to crack.
I'd slap a new cylinder head on the 2000 block from Clearwater Cylinder that fixed the defect and throw that sucker in.
Yeah I wouldn't do an entire engine swap unless yours grenades or you are swapping in something much newer/better like a 4.6L stroker or a reman engine.Yeah I saw something about the heads cracking .. his grand has 138k miles ... ok ..looked up prices and it's about 400 to replace cam and lifters with head gasket set... thought the cam was 500 alone was why I wanted to do it.. for that price me and the kid could change them out one weekend.. can't go without the jeep as it's daily driven .. and don't wanna pull the engine unless rebuild or replace
Head has to come off, at least that's how I've done it.Can the lifters be removed without pulling the head or has the head absolutely got to come off
It's been ticking since I got it 3 yrs and 86k miles ago ...runs really good with no smoke at all and only leaks about half a quart between changes so I'm lead to believe the bottom end is in good shape but damn that's a lot of miles... would love a v8 with trans to go with it but money is an issue amd too much involved in swapping ecm and wiring... only ever changed plug and play engines ...kinda hesitant to get into changing to different engine... considering emissions ..if not for all that I would happily get a carb 350 and drop it in.Yeah I wouldn't do an entire engine swap unless yours grenades or you are swapping in the bottom end is in good shaoe bit thats alot of miles something much newer/better like a 4.6L stroker or a reman engine.
