CJs have a 5X5.5 bolt pattern FYI. What size tire are you going to run on them? If it is a typical 12.50 wide Mud Terrain, the 15X10 width should work fine. Many people who wheel in the rocks a lot would prefer a 15X8 for better bead retention off road, but it really depends on what you use your Jeep for. On the street, 15X10 is actually better. If you are a rock monster, then 15X8 will be less problematic offroad, although my wife's TJ has had 15X10s on it for 11 years and we have wheeled it hard on the rocks aired down to 10 PSI with no bead retention problems. One more note, aluminum wheels typically hold a bead better than steel wheels because the bead retention ridge on aluminum wheels is usually more pronounced.
