Ok so I need to know if these wheels will physically bolt on 18x7.5 +44 5x114.3 71.5 center bore it was mainly the offset I was wondering about and thanks in advance
5x114.3 is the same as 5x4.5 correctThe lug pattern has to be 4.5” and I’m not seeing that in your description
Thanks for your reply so will they fit ? Sorry still learning all this+44, 25mm =1"
so 1" + a hair under 3/4 (=19mm)
then a 7.5 is 3.75 at 0. now add your 1.74" and your at about 5.5" of backspace.
Ok thanks man5.5 is pretty deep that.s like JK rims. being 18 might make it able to get around front end components,
that i cannot answer.
Ok and it has I think a 3” lift not 100% sure on this bc it was already on when I got itthat equates to a 30.5 x10.5.
on a TJ backspace of 4.5 IIRC it'd probably work on the deeper wheel it may be an issue.
it's a deep rim wait for others to chime in here.
you can measure the springs top to bottom more than 12" up front is lift..... more than 8" in the rear is lift.Ok and it has I think a 3” lift not 100% sure on this bc it was already on when I got it
