Larry Hall Member Joined May 12, 2018 Messages 30 Location Baxley,Ga. Sep 29, 2018 #1 Will the hardtop from a YJ fit a TJ without modification?
CasperLLY TJ Enthusiast Joined Feb 12, 2018 Messages 134 Location US Sep 29, 2018 #2 I don't believe so Sent from my SM-G950U using Tapatalk
GeorgeSully TJ Enthusiast Joined Sep 1, 2018 Messages 236 Location South Carolina Sep 29, 2018 #3 I thought the yj’s were shorter Sent from my iPhone using Tapatalk
Fouledplugs TJ Guru Supporting Member Joined Jun 19, 2017 Messages 7,049 Location Alabama/North Carolina Sep 29, 2018 #4 Nope. The TJ/LJ uses latches on the upper windshield channel, the YJ utilizes screws.
glwood Jeepless Supporting Member Joined Sep 16, 2016 Messages 6,611 Location Albuquerque, NM Sep 29, 2018 #5 The doors on a YJ are a different shape than TJ doors, so the top would be shaped differently also.
OP Larry Hall Member Joined May 12, 2018 Messages 30 Location Baxley,Ga. Sep 30, 2018 #6 thanks to all
astjp2 TJ Guru Supporting Member Joined Aug 22, 2018 Messages 6,198 Location Utah and Alaska Sep 30, 2018 #7 If you do a search, you will find that guys will trim the top in the front and screw down the front of the top, so yest it does fit but it does also require modifying the top to get it to work. Tim
