Winch solenoid mounting question
Twopoint
TJ Pupil ... and all it entails...
Lifetime Supporting Member
Kitsap WA
I am looking at the firewall as a possible mounting location for my winch isolater solenoid.
I noticed 2 divots above the AC lines, and wondered if anybody knew the clearance behind them?
as I want to install 2 riv nuts.
100890
this is what I am trying to install in that location
100891
Open glove box. Remove glove box door. Remove fuse panel and push over to the side. Peek at the firewall with a light source, locate those two dimples on the inside of the firewall and then you will know.
Is that solenoid up to the significantly greater than 400 amperes load a winch can draw when under load? For that reason I'm no fan of using a solenoid in that circuit, not many are up to a sustained load >400 amps.
Reactions: oldb
so, it looks like about a quarter of an inch clearance around the diameter of the divot.
da-yum! it looks like it was designed for it!
Reactions: mikespine
How are you going to wire it up or control it? There is a similar solenoid at the winch, just wondering what it really does. I get that it is extra protection but how does it get used during a recovery. Trying to learn and not criticize for what it's worth.
That solenoid's purpose is strictly to turn on or off all the power to the winch. Ostensibly it's an added safety benefit but to me it's an additional potential point of failure. I personally don't believe a winch needs an additional on-off switch any more than the starter motor does.
Ya, I was just trying to work it out. You have the controller in your hand standing off to the side how do you operate it? Or does it tie in to the in cab control? Just interesting to see how it would be wired.
That solenoid he's going to add has nothing to do with anything being done during a recovery. It's just an on-off switch to allow the winch to be disconnected from the battery if you're worried about vandalism or the solenoids inside the winch have locked up and the winch has gone out of control.
So if the winch goes out of whack how do you control the solenoid? That's all I'm asking. Like I said, I get the purpose I'd just like to hear how it is going to be physically controlled.
By a simple small on-off switch that can be mounted anywhere.
Reactions: pagrey
after being a motor electrician for over 25 years, I like the ability to remove power from equipment.
in this case, in the event of a front end collision, I don't have a possible short to ground. At a 2 gauge or better, the battery will go before the cable does.
the other reason is so someone doesn't play with it and short the pins, its an urban myth, but better safe than sorry
as to your question, I will have 2 switches in the cab, one to shut (energize) the solenoid, the other a 2 way momentary to control the winch. one direction in, the other out.
check out http://www.12voltguy.com/jeep for ideas
so, one run to the hardware store for some m6 screws and it is good to wire.
verified I have a good ground for control
thanks guys, it never occurred to look there as I was thinking it was still behind the AC box
100911
Reactions: MountaineerTom
Edit: I see you replied just minutes before I did that you got it. Sorry. Glad it worked out for you.
I don't know if this will help you, but here's a couple pics of when I had my HVAC out for a heater core and A/C core change. It might give you some reference points. It looks like the actual HVAC box itself wouldn't be in the way.
Reactions: Zorba and Twopoint
If I had not gotten the answer, this would have worked for me! thanks!
Do you plan to do that for your starter motor too? Electrically a winch motor and starter motor are essentially the same thing and both are wired directly to the battery. If not why not?
This is not an airplane that needs a master contactor or an MCC, if you get into a wreck bad enough to short out the winch power cables, the wires would just melt long before the battery blows up.
Reactions: Jerry Bransford
