Windshield wipers on my 06 LJ Rubicon do not work at any speed. So far I have done the following to troubleshoot:
1. Bench tested wiper motor. The wiper motor works properly at low and high speeds
2. Used multimeter to test power at the wiper motor harness. Multimeter shows a little over 12 volts at the constant power pin but no volts when testing the low and high speed pins.
3. Verified relay in the PDC functions.
What else should I test? Figured the issue must be with the wiper switch at the steering column but maybe there is another possibility. Appreciate any help.
