Wolfbox dash cam connections
rjfoster03
Greensboro, NC
I have a 2004 TJ and wanted to see if anyone has installed an aftermarket dash cam setup. If so, which fuse slots did you use to connect the ACC (accessory cord) and BATT (battery cord) to? I am wanting to have power when the ignition is on (for the ACC wire) or at all times (for the BATT wire).
Thanks in advance.
Thanks in advance.
Did u install it?
