I picked up a new (to me) 02 TJ a few weeks ago, knowing it was kind of a work in progress....... lifted with Rancho springs & shocks, Ford 8.8 rear diff, 33" BFGs, SYE, etc. The PO knew the springs were mediocre (at best) & had purchased a complete set of Rustys Off road coils (included in the sale). During the test drive I saw that the rear was bottoming out on the bumpstops. Then a week or so after I bought it, I noticed a few other issues...... rear diff has a larger than normal cover on it that was hitting the gas tank skid plate. Ford 8.8 has 1" spacers on it so the rear tires don't hit the upper spring perches, but the fact that their only 1" thick on stock lug bolts means the rims are not flat against the spacers.
So last weekend I installed the Rustys springs. The fronts are about the same height, but larger diameter & lifted about an inch. The rears lifted about 5", which was great for clearing the diff cover from the gas tank skidplate, and the bumpstops, but I'm finding out is way too much. I have a squeaksqueaksqueak that gets faster as i speed up. And a vibration, possibly death wobble. The lift changed the pinion angle. I pulled the driveline out & took it in for inspection and was told the u-joint was junk & it was out of balance. $150 later & there's no change.
Yesterday I tried to adjust the pinion angle by removing the upper control arms to lengthen the heim joints a bit. But I had a tough time getting one of the control arms out & the other was a bitch.
I'm starting to think the Rustys springs are not going to work out. If I go back to shorter springs, I'll need a normal size diff cover & cut down the bumpstops.
Thinking about taking it in to Hazzard Fab....a local 4x4 shop. In a conversation I had with them last week, he said he thought the lift was too much & suggested a progressive spring, maybe 3" shorter. Which should ride nice on road & off, plus might get past the pinion angle problem.
Today I stuck the GoPro under there on the test drive. Way too many squeaks & creaks. Plus at about 3:20 it goes into the death wobble.
Some pics of it all.....
Feel free to give your 2 cents
