My wrangler is running poorly. Rough idle. Sputtering and almost jerking feeling on acceleration. Not a whole lot of power until I get passed 2nd. Initially was thinking a tune up but the check engine light was on so I had it checked at Autozone and O’Reilly Auto Parts. I don’t know the numbers/codes but Autozone gave me four options- upstream & downstream O2 sensors, fuel filter, fuel pump. O’Reilly seemed more knowledgeable (take that for what it’s worth) but they said it read Upstream/Downstream O2 sensors & lean fuel.
Not sure if this helps but I went to a car wash (pretty high pressure, get undercarriage and everything) and immediately when I pulled out it started sputtering and sounded like it was about to die. Was obviously struggling and has been ever since. Maybe something got wet?? Damaged from the water/wash??
Not sure where to start. I was thinking O2 sensor, mainly the O2 upstream. Thoughts? Rather not go fuel pump route and deal with the tank. Thanks for any and all help!
