While the front axle is a high pinion Dana 30, it has an axle disconnect built into the axle housing and is setup for spring under..so it’s not a good candidate for swapping into the TJ.
Depening on year and engine, the 231 might be worth having.
Depending on trans, I’m pretty sure the radiator, if in good shape and an OEM, could be worth snagging.
You could grab the radiator, though it’s the older 2-row design. Starter, door handles, brakes, some engine parts for the XJ maybe, I think fan blade and radiator shroud? TJ shroud is different but I believe they bolt up and work the same. Bulb sockets should be the same, tail lights could be taken if rewired. Honestly there’s not a lot. There’s probably some I’m forgetting too. Transfer case and transmission could possibly be good to take.
