NovaTJ
Jerry I hear you having turned 68 yesterday! Building my third TJ and getting ready to hit the rocks at Rausch Creek in Pennsylvania for the 8th time. You're not getting older, you're getting better!
Well aside from the bad news of having turned 70 last summer, the good news is the docs figured out I don't have a torn rotator cuff after all. My last doc finally correctly diagnosed it as a "frozen shoulder" which can happen after a shoulder injury. To stop the pain, the shoulder decides to limit shoulder movement by adhering the shoulder together inside. The VA is giving me free weekly physical therapy and my therapist guarantees it'll be fine by the time she's done with me. When she first rotated my arm fully up to start limbering it up, it crunched like someone took a big bite out of fresh apple That sound was of the adhesions being pulled apart. Yowsa....Between my bent/swollen/bruised little toe I think I broke last night when I jammed it into the door jamb, the arm I damned near broke Saturday, and the torn rotator cuff (water skiing accident 20 years ago), I can barely move in the mornings. Not to mention I freaking turn 70 next month.
Sounds like that was good news for you! I’ve been thinking I have a torn rotor cuff, but watched a video on u tube and now hearing you, I’m hoping there is a simpler solution to my pain. I’m going to start some PT on my own at some point here to see if it helps. Glad you are on the road to recovery.Well aside from the bad news of having turned 70 last summer, the good news is the docs figured out I don't have a torn rotator cuff after all. My last doc finally correctly diagnosed it as a "frozen shoulder" which can happen after a shoulder injury. To stop the pain, the shoulder decides to limit shoulder movement by adhering the shoulder together inside. The VA is giving me free weekly physical therapy and my therapist guarantees it'll be fine by the time she's done with me. When she first rotated my arm fully up to start limbering it up, it crunched like someone took a big bite out of fresh apple That sound was of the adhesions being pulled apart. Yowsa.
My physical therapist gave me a rope & pulley system that hangs off the top of a door and that is responsible for most of my improvement. I use my good arm to repeatedly hoist my bad shoulder's arm up & down which is really helping to free up the shoulder. It is key that the arm going to the bad shoulder gets a free ride up & down and that your good arm does all the work, don't try to assist or help with the bad shoulder at all.Sounds like that was good news for you! I’ve been thinking I have a torn rotor cuff, but watched a video on u tube and now hearing you, I’m hoping there is a simpler solution to my pain. I’m going to start some PT on my own at some point here to see if it helps. Glad you are on the road to recovery.
Thanks. My symptoms are a bit different . Based on my internet diagnosing, I think I have bursitis or impingement. From what I’m reading , it’s a ton of excerises to do daily. But it’s gotten so bad that it’s really hurting doing simple tasks so I need to try something . Enjoy your pulley system, and getting movement back in your arm.My physical therapist gave me a rope & pulley system that hangs off the top of a door and that is responsible for most of my improvement. I use my good arm to repeatedly hoist my bad shoulder's arm up & down which is really helping to free up the shoulder. It is key that the arm going to the bad shoulder gets a free ride up & down and that your good arm does all the work, don't try to assist or help with the bad shoulder at all.
You use the rope & pulley while seated facing away from the door with the bad arm's shoulder straight out front, then straight out to the side with the hand positioned so the thumb is up. She gave me a Home Ranger pulley system like you can find at https://www.amazon.com/s/ref=nb_sb_ss_c_1_15?url=search-alias=aps&field-keywords=home+ranger+shoulder+pulley&sprefix=home+ranger+sho,aps,223&crid=1CH845XP0VCUY&rh=i:aps,k:home+ranger+shoulder+pulley
She also suggested placing the bad arm in back & working it up-down with the pulley & rope like you're reaching upward to scratch between the shoulder blades or base of the neck. My shoulder still occasionally pops & crunches but it's definitely way better and getting better every day. She explained that with a frozen shoulder that this type of therapy can only help, it can't hurt it.
Keep in mind you're moving the bad arm in an ever increasing range to increase the range of motion for the shoulder to eliminate/break free the shoulder joint's internal adhesions that the shoulder grew inside as a defense to immobilize the shoulder to stop the pain from the earlier injury. That pain eventually reduces the shoulder's range of motion (via those adhesions that developed) to where you can no longer raise the arm up to even a horizontal position. Every time I think about it I raise my arm up over my head and work it back & forth as part of the therapy The further up & to the rear, the better. Good luck with it, I'm thrilled from having learned my shoulder pain was not really from a torn rotator cuff as several doctors had mis-diagnosed years earlier. Be sure to read up on therapy for a frozen shoulder too.
Jerry- I feel your pain -63 here. I went thru the thinking rotator cuff thing years ago and right at it's worst went to Canada on a 120 mile canoe trip and ate advil like candy- at the end i no longer had shoulder problems, My problem turned out to have been mixing office work with splitting wood with an 8# maul. No longer have that problem.
In 2008 i broke my back but 3 years after that I was backpacking again but yes- advil is part of life nowdays but how we think determines how young we feel.
My boss goes rock crawling with guys in their 70's and 80's - still crawlin and still rolling em over.
I hear you on the 8 lb splitting maul. I use to split alot of my wood that way. But 4 years ago my surgeon that fixed both my shoulders said "no more". I still cut all my firewood.... I carry the rounds to the hydraulic wood splitter that my wife likes to run.....team work!Jerry- I feel your pain -63 here. I went thru the thinking rotator cuff thing years ago and right at it's worst went to Canada on a 120 mile canoe trip and ate advil like candy- at the end i no longer had shoulder problems, My problem turned out to have been mixing office work with splitting wood with an 8# maul. No longer have that problem.
