Cat to Manifold Bolt Size / Length
ItchyDong
Easily Offended
Alabama
2006 LJ. I need to replace my Cats when I get home from deployment. I'm trying to get a parts list together. I'm looking at https://www.amazon.com/gp/product/B0027A6PAA/?tag=wranglerorg-20. A few reviews say I'm going to need 1/2 longer bolts. I looked in my parts manual and it shows 06505754AA. I did some searching online and can't find any info on the bolts size, pitch, etc. Anyone know this offhand so I can find something a little longer?
I don't remember off the top of my head the bolt size, but figured I'd share to not forget to get the nuts since they're single use (they're stover style locking nuts). Part 6506546AA
Yeah those are on the list too. Looks like eBay is the only way I can get ahold of those for 50 damn dollars after shipping. I may just run a washer and nut combo.
I installed this exact product earlier this year and didn't need longer bolts. It probably would be easier to use them, but once you get the downpipe at the right angle the original bolts will screw in.
Perfect. Thank you!
For anyone contemplating this job, I strongly suggest you DON't use a washer nut combo. The PO of my Jeep used washers and nuts. When I replaced my RMS, I had to remove the fender and a lot of other stuff to get to the washer and nuts on the exhaust flange.
I replaced the washers and nuts with OEM captive nuts.
I mean, I'd have no problem accessing it? To each is own.
Does anyone know what size / thread count bolts to use for the OEM captive nuts part # 6506546AA. I have tried 10mm 1.5 pitch bolts & 3/8 course thread bolts. Both of them stop when I get the first turn in. The factory bolts part # 6505754AA are at least $30. There has to be some size / pattern that works for this nut
any success? I'm looking for this also...
If I remember correctly, I used a 10mm 1.5 and “forced it” through. It had initial resistance and then went in after
For anyone looking for this info in the future, the bolts are M10 x 1.5 with a 15mm hex head and about 45mm long. Hex head is unusually thick at 9.2 mm or 3/8.
Thread and pitch verified with a thread gauge
Looks like McMaster Carr has very similar bolts.
Reactions: macleanflood
Awhile back I ordered the cats and plumbing while they were $250. They are out of stock of those now. Figured I might as well order the bolts and nuts since y’all have posted all this great info. The cost for four bolts and the four capture nuts plus shipping came up to $92. $8 for each capture nuts $12 for each bolt. WOW. GOTTA MAKE THEIR MONEY SOMEWHERE!! but between new cats and bolts I’ll probably never need to replace any of it. 🥲😜
Reactions: Spike Strip
