I love visuals! Thank you!If the provided screws thread into the v shaped black clip, you probably need to place the v clip with the smaller hole on the bottom of the adapter plate and the other side on top of the speaker. Then run the screw in to hold the speaker to the adapter plate.
The other question, black goes on the small spade, white goes to the bigger spade.
Sent from my Pixel using Tapatalk
Thank you! Im waiting for Dave. When I tried putting them on, it seemed like it didn't want to go. And with the kind of day I've been having, my luck would be I break it. But at least I know I'm on the right track!Yes, you need those little bracket things. But one side on the top and your screw through it and the speaker mount and then out the back through the backside of that little bracket.
For the adapters, just slide them on to the mail connection. Wow on one side, one on the other. Then test the speaker. If it doesn't sound right switch those two connections
I ordered them online through amazon . From one of the members threads link . I’m struggling getting them in so not sure if it’s the bracket or the speakerDoesn't help your install, but where'd you get the speakers...?
5.25 speaker . Is what many have installed with the exact adapter and speaker that numerous used on here. I messaged @Jorge Bolivar who installed the same. Daves gonna cut the bracket . Just want to get them in . Thanks for the info on the baffle. Sounds like a waste of 10.00.@Kathy, what size speaker are you installing? I’m running a 4” Component that fits in there easy. Looks to me if you cut that bracket they still might not fit. Ps, I installed those baffles yesterday and I didn’t notice a difference at all.
@Dave K. is correct, you will need to cut the curved portion of the metal bracket/strap in order to install the 5.25" speakers.View attachment 23134 View attachment 23135 I can’t get the speaker to fit in the hole?? Did anyone need to cut the inside bracket to get the speaker to fit? Struggling here hoping for some guidance. Thanks!
Here is the exact parts I purchased for the install. The adapters make it plug and play and no wiring needed.Doesn't help your install, but where'd you get the speakers...?
