Where did you get such exact caster angle numbers for 35's?For 35s the caster should be 5.15-6.85" so everything looks in spec but I don't know how the front driveshaft isn't shaking you to death with 6" of lift and 6° of caster.
Local Firestone shop where I have a lifetime alignment deal. Those folks must hate me! Other than, I don’t really feel any bad vibes to speak of, even in 4x4. But I’ll go ahead and adjust for less Castor in favor of better pinion angle.Where did you get such exact caster angle numbers for 35's?
If you don’t have vibes do not adjust anything. You want as much caster as you can have without vibes.Local Firestone shop where I have a lifetime alignment deal. Those folks must hate me! Other than, I don’t really feel any bad vibes to speak of, even in 4x4. But I’ll go ahead and adjust for less Castor in favor of better pinion angle.
You don't have "bad" vibes, do you feel any vibes whatsoever?I don’t really feel any bad vibes to speak of, even in 4x4.
Is not having vibes that unusual for this much castor ?You don't have "bad" vibes, do you feel any vibes whatsoever?
that much caster at that much lift, somewhat unusual, yes.Is not having vibes that unusual for this much castor ?
Yes. I have 4" of lift and run mine at 5.5 to prevent vibes. Anything over 5.8 degrees of caster and I get vibes.Is not having vibes that unusual for this much castor ?
NopeYou don't have "bad" vibes, do you feel any vibes whatsoever?
Here is the driveshaftJust re adjusted my control arms and got an alignment.
6” lift with 35s. Any thoughts ?
I adjusted the armsdid you adjust the arms or did the shop do it while it was on the rack?
It looks decent. I questioned it because it you adjust caster while up on the rack and if you don't re-sweep afterwards, you will have an inaccurate reading.I adjusted the arms
Jerry I just remembered that I have left the transfer case drop in place, could that be why I don’t feel front vibrations with that much castor?You don't have "bad" vibes, do you feel any vibes whatsoever?
Possibly. And it's caster, not castor which is a bean that castor oil comes from.Jerry I just remembered that I have left the transfer case drop in place, could that be why I don’t feel front vibrations with that much castor?
