I want to change my power brake booster.
Kindly advise which brand is the best?
For jeep wrangler tj 97 wheels 33 rim 15
Best is OEM Mopar.I want to change my power brake booster.
how about for the master cylinder? Is it as critical? Just ordered BMBs, still putting together a list of other components to replace while at it. I was able to order a new mopar booster but now I’m thinking about the master as well.Best is OEM Mopar.
Not as critical.how about for the master cylinder? Is it as critical? Just ordered BMBs, still putting together a list of other components to replace while at it. I was able to order a new mopar booster but now I’m thinking about the master as well.
No, the TJ and WJ run the same 1" bore master with a very similar size dual diaphragm booster. That is due to the stock TJ single piston caliper having about the same piston surface area as the dual pistons in the WJ calipers.I saw online a popular modification on TJs and XJs is upgrading the brakes from a WJ, etc. does that mean you also have to upgrade the master cylinder and brake booster?
