Hey guys I'm thinking through the process of replacing torque boxes on a TJ, specifically bonding the torque boxes to the floor pans. I'm not a body guy but have replaced my share of quarter panels and have always plug welded overlapping seems. I'm curious of a a couple other methods...
Or just plug weld the floor to the torque box and call it done. What's a good way to rust proof those seams? Will weld-thru primer be enough to seal out future corrosion? The main long term goal is corrosion prevention.
This isn't my thing but it is something that needs getting done so I am going to learn how to do it. Looking for some advice. Thanks!
- Panel Adhesive. Well....it generally isn't supposed to be used alone for structural applications. And clamping would be difficult.
- Panel Adhesive + High Strength SS Rivet's. Grab some Stainless Steel 1/4" sealing blind rivets and use a back-up washer in the back and install every 3 inches or so. Use plenty of panel adhesive and the rivets and washers will apply the clamping force.
