You can buy SetUp Bearings kits if your old bearings are shot.
https://www.rustysoffroad.com/jeep-...oints-and-more/ring-and-pinion-setup-bearings
Those things aren't cheap! I bought some brand new bearings to make my own set up bearings. It's really not very difficult (just takes time) and I saved a lot of money that way.You can buy SetUp Bearings kits if your old bearings are shot.
Double check behind me but pretty sure those are correct. Rock auto lists in their descriptions Dana 30: front crush sleeve (aka for TJ).You are da man! Thanks !
That’s my plan!I also found it helpful to watch other regear videos. I’ve watched a few on mustang 8.8s and some on 14 bolts.
Everyone has a slightly different way of doing things and if you sum them all up you get pretty well educated on what to do, and how.
If you don’t want to spend all of that time your best bet is to watch @hosejockey61 regear videos on repeat 3-4 times.
Could you explain what this is?I bought the ECGS setup bearings and have made a pair at home. Both work just fine.
East Coast Gear Supply. Good shop to get stuff from.Could you explain what this is?
HF unit? Could you give me a part number or link….or do you mean harbor freight? Cause I’m looking at the 12 ton press , But they don’t have it in stock. Figures.Don't do this to the new bearings. Also, if you need a press, I recommend the HF unit.
Ecgs. Btw…..is that you ankle in the profile picture? Ok edit….east coast gear supply. Got itAre you asking what setup bearings are? Or what ECGS is?
i appreciate the tip, but my better half is ok with it, and I want one! She knows me enough to realize I am going to get my money’s worth! The bigger issue is the room I have in the garage LOL…If you are not needing a press very often and do not want the expense of one look around for a machine shop, driveline shop or the like and you will probably find that they will press your bearings for $30-50.
