Are you going to use 3/8” DOT. Pushlock to plumb your rig?Started messing about to see how my air compressor will mount (Viair 450c on the ABS tray). Output hose wants to occupy the same space as the brake booster - so I'll put a 1/4" street ell on the output port so the hose will go in a better direction. Ended up having to order the ell online, neither Ace nor Homeless Despot had them in stock.
TAILONZ PNEUMATIC Male Elbow 3/8 Inch Tube OD x 1/4 Inch NPT Thread Push to Connect Fittings PL-3/8-N2 (Pack of 10) https://www.amazon.com/dp/B07R87H7S8/?tag=wranglerorg-20
