Has anyone used the Kia Air pump as a replacement for their Locker Pump? Was wondering if in fact it is the same pump with the same output air pressure.
Craig
Craig
But he does have rubicon axles and a 5:1 TCIt's identical from what I've read.
Someone did this, I want to say it was @Alex01, but he doesn't have a Rubicon, so maybe not.
I just installed an ARB pump with 2 outlets. On the one going to the Rubicon lockers I installed a regulator that cuts the pressure down to 5 PSI. Works great!
Just lost my front locker, this thread might come in handy
I need to do this as I can not find any OEM pumps. Would you mind sharing your parts list and how you did this? I was thinking of doing this but not sure which ARB model to get and all the parts needed to do this. I know the factory lockers have to be run at 5psi. Thanks in advance.I just installed an ARB pump with 2 outlets. On the one going to the Rubicon lockers I installed a regulator that cuts the pressure down to 5 PSI. Works great!
Where did you find this regulator to cut it down to 5psi? Having trouble finding one myself. Thanks in advance.I just installed an ARB pump with 2 outlets. On the one going to the Rubicon lockers I installed a regulator that cuts the pressure down to 5 PSI. Works great!
Were you able to use the original switch to turn the lockers on and off, or is your solution a bypass ... just turn on the pump and the lockers engage? Also, can you post the regulator information? So many to choose from. Thanks!I just installed an ARB pump with 2 outlets. On the one going to the Rubicon lockers I installed a regulator that cuts the pressure down to 5 PSI. Works great!
My (overly complex) Rubicon locker switching circuit stopped working so I replaced it with two heavy-duty on-off switches. It was simple to bypass the wiring, I just wired the locker compressors like I would 12 volt light bulbs with a 5 amp fuse for both compressors.Were you able to use the original switch to turn the lockers on and off, or is your solution a bypass ... just turn on the pump and the lockers engage? Also, can you post the regulator information? So many to choose from. Thanks!
I've also started to recently look into blood pressure machine pumps. They pump out and hold 7psi.
I do use a manual blood pressure bulb as a backup in my kit and 2-3 pumps give 7-8psi and they max out at around 11psi.
