Ordered the Savvy T-case shifter kit. There were nine of them available 1 week ago, it was down to 3 this AM, so I pulled the trigger on it as Goddess knows when they'll be available again or at what cost.
Just checked Amazon - they're now sold out, at least there. Supposed to get it next week - wonder if I'll get a sticker... ;)
I bought my Viair air compressor for $237 last month - 2 weeks later it was $317! This ain't gonna get better anytime soon, so if you see something you need at a good or at least acceptable price, you'd better grab it...
Oh, and I checked the price on the air compressor (450c) as well: Now up to 329!
Last year I rented an excavator and put a my French Line in front of my house. I had just enough time to make a short run through my back 2 acres. Down a holler and back up. Today it’s nice. I took doors off and drove around in my back yard because I can. 😃
The only thing I miss about living in Arkansas was my back yard, which looked pretty much the same as this. Lived outside of Mountain View, in Fox, AR.
Reactions: CptnMurica
Man that’s banjo country for realz 😂
Had jobs out that way.
You must have the patience of Job! Great job. What are those green pucks in the second picture?
Silicon blocks...all the wires are run through to the relay contacts...then you push the block in for more water resistance.
It's a great relay block.
A prebuilt touch screen is cool...and probably easier...but my fingers are too dry and I never can make those buttons work.
That and the switches and panel fit the 90s vibe of the Jeep.
Reactions: Fonz54
What brand wheels?
QuadraWrec- The specs say the center caps may fit it but if they don’t I’m going to put some stickers on them I’ve got ordered
I’m not too big into faking stuff but I’m going to do this- women fake stuff all the time- There are several industries built around that, and folks go to medical school to help ‘em.
I should probably take that back- I fake it every day as a knowledgeable, normal human being
QuadraWrec- The specs say the center caps me see it but if they don’t I’m going to put some stickers on them I’ve got ordered
I should probably take that back I fake it every day as a knowledgeable normal human being
So true!!!!! If folks here only knew :ROFLMAO: :ROFLMAO: :ROFLMAO:
You should have received a wiring harness with relay and a switch.
The eaton elocker did indeed come with a wiring harness and switch. I'm not using the provided switch but instead wiring it into a powered switch panel (similar to SPod). Trying to figure out what wires I run to the (+) and (-) on the switch panel.
On the elocker harness I think I ground the black, and attach the red and red/yellow to the switch panel? The provided switch and other connectors go into the parts bin...
Thoughts?
Wire harness pic attached.
Thoughts?
  • Eaton-ELocker-wiring-schematic.pdf
Thoughts?
You're using your own relay...the only thing you need is the SO cord with the white and black wires. Use the provided weather pak connectors on the dif/cord... trim the other side to fit...white to the relay... usually pin 30 on a 5 pin, black to ground.
